Block delayed Majorize-Minimize subspace algorithm for large scale image restoration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems Année : 2023
Abstract In this work, we propose an asynchronous Majorization-Minimization (MM) algorithm for solving large scale differentiable non-convex optimization problems. The proposed algorithm runs efficient MM memory gradient updates on blocks of coordinates, in a parallel and possibly asynchronous manner. We establish the convergence of the resulting sequence of iterates under mild assumptions. The performance of the algorithm is illustrated on the restoration of 3D images degraded by depth-variant 3D blur, arising in multiphoton microscopy. Significant computational time reduction, scalability and robustness are observed on synthetic data, when compared to state-of-the-art methods. Experiments on the restoration of real acquisitions of a muscle structure illustrate the qualitative performance of our approach and its practical applicability.
main.pdf (3.65 Mo) Télécharger le fichier
hal-04281658 , version 1 (30-08-2022)
hal-04281658 , version 2 (07-01-2023)
hal-04281658 , version 3 (31-01-2023)
hal-04281658 , version 4 (13-11-2023)
Paternité
Mathieu Chalvidal, Emilie Chouzenoux, Jean-Baptiste Fest, Claire Lefort. Block delayed Majorize-Minimize subspace algorithm for large scale image restoration. Inverse Problems, 2023, Special Issue on Optimisation and Learning Methods for Inverse Problems in Microscopy, 39 (4), pp.044002. ⟨10.1088/1361-6420/acbdb9⟩. ⟨hal-04281658v4⟩
163 Consultations
71 Téléchargements
