An FPT Algorithm and a Polynomial Kernel for Linear Rankwidth-1 Vertex Deletion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Linear rankwidth is a linearized variant of rankwidth, introduced by Oum and Seymour [Approxi-mating clique-width and branch-width. J. Combin. Theory Ser. B, 96(4):514-528, 2006.], and it is similar to pathwidth, which is the linearized variant of treewidth. Motivated from the results on graph modification problems into graphs of bounded treewidth or pathwidth, we investigate a graph modification problem into the class of graphs having linear rankwidth at most one, called the Linear Rankwidth-1 Vertex Deletion (shortly, LRW1-Vertex Deletion). In this problem, given an n-vertex graph G and a positive integer k, we want to decide whether there is a set of at most k vertices whose removal turns G into a graph of linear rankwidth at most one and if one exists, find such a vertex set. While the meta-theorem of Courcelle, Makowsky, and Rotics implies that LRW1-Vertex Deletion can be solved in time f (k) · n 3 for some function f , it is not clear whether this problem allows a runtime with a modest exponential function. We establish that LRW1-Vertex Deletion can be solved in time 8 k · n O(1). The major obstacle to this end is how to handle a long induced cycle as an obstruction. To fix this issue, we define the necklace graphs and investigate their structural properties. We also show that the LRW1-Vertex Deletion has a polynomial kernel.
15.pdf (615.06 Ko) Télécharger le fichier
lirmm-01264011 , version 1 (15-11-2018)
Paternité
Mamadou Moustapha Kanté, Eun Jung Kim, O-Joung Kwon, Christophe Paul. An FPT Algorithm and a Polynomial Kernel for Linear Rankwidth-1 Vertex Deletion. IPEC 2015 - 10th International Symposium on Parameterized and Exact Computation, Sep 2015, Patras, Greece. pp.138-150, ⟨10.4230/LIPIcs.IPEC.2015.138⟩. ⟨lirmm-01264011⟩
236 Consultations
121 Téléchargements
