Humanoid robots in aircraft manufacturing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Magazine Année : 2019
Stéphane Caron
Pierre Gergondet
  • Fonction : Auteur
  • PersonId : 935991
Arnaud Tanguy
Pierre-Brice Wieber
Adrien Escande
Kevin Chappellet
Patrice Rabate
  • Fonction : Auteur
We report results from a collaborative project that investigated the deployment of humanoid robotic solutions in aircraft manufacturing for some assembly operations where access is not possible for wheeled or rail-ported robotic platforms. Recent developments in multi-contact planning and control, bipedal walking, embedded SLAM, whole-body multi-sensory task space optimization control, and contact detection and safety, suggest that humanoids could be a plausible solution for automation given the specific requirements in such large-scale manufacturing sites. The main challenge is to integrate these scientific and technological advances into two existing humanoid platforms: the position controlled HRP-4 and the torque controlled TORO. This integration effort was demonstrated in a bracket assembly operation inside a 1:1 scale A350 mock-up of the front part of the fuselage at the Airbus Saint-Nazaire site. We present and discuss the main results that have been achieved in this project and provide recommendations for future work.
ram2019.pdf (11.07 Mo) Télécharger le fichier
lirmm-02303117 , version 1 (02-10-2019)
Abderrahmane Kheddar, Stéphane Caron, Pierre Gergondet, Andrew Comport, Arnaud Tanguy, et al.. Humanoid robots in aircraft manufacturing. IEEE Robotics and Automation Magazine, 2019, 26 (4), pp.30-45. ⟨10.1109/MRA.2019.2943395⟩. ⟨lirmm-02303117⟩
603 Consultations
1933 Téléchargements
