VLSI-SoC: Forward-Looking Trends in IC and Systems Design 18th IFIP WG 10.5/IEEE International Conference on Very Large Scale Integration, VLSI-SoC 2010 Madrid, Spain, September 27-29, 2010
Conference papers
Joint Optimization of Low-power DCT Architecture and Effcient Quantization Technique for Embedded Image Compression
YO - YNCREA OUEST (20 rue Cuirassé Bretagne, 29200 BREST, FRANCE
- France)
Abstract : The Discrete Cosine Transform (DCT)-based image com- pression is widely used in today's communication systems. Signi cant research devoted to this domain has demonstrated that the optical com- pression methods can o er a higher speed but su er from bad image quality and a growing complexity. To meet the challenges of higher im- age quality and high speed processing, in this chapter, we present a joint system for DCT-based image compression by combining a VLSI archi- tecture of the DCT algorithm and an e cient quantization technique. Our approach is, rstly, based on a new granularity method in order to take advantage of the adjacent pixel correlation of the input blocks and to improve the visual quality of the reconstructed image. Second, a new architecture based on the Canonical Signed Digit and a novel Common Subexpression Elimination technique is proposed to replace the constant multipliers. Finally, a recon gurable quantization method is presented to e ectively save the computational complexity. Experimental results obtained with a prototype based on FPGA implementation and com- parisons with existing works corroborate the validity of the proposed optimizations in terms of power reduction, speed increase, silicon area saving and PSNR improvement.
https://hal.archives-ouvertes.fr/hal-00685875 Contributor : Maher JridiConnect in order to contact the contributor Submitted on : Wednesday, May 3, 2017 - 3:59:16 PM Last modification on : Thursday, November 5, 2020 - 3:32:07 PM Long-term archiving on: : Friday, August 4, 2017 - 1:27:24 PM
Maher Jridi, Ayman Alfalou. Joint Optimization of Low-power DCT Architecture and Effcient Quantization Technique for Embedded Image Compression. 18th International Conference on Very Large Scale Integration (VLSISOC), Sep 2010, Madrid, Spain. pp.155-181, ⟨10.1007/978-3-642-28566-0_7⟩. ⟨hal-00685875⟩
