HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Self-Timed Rings: A Promising Solution for Generating High-Speed High Resolution Low-Phase Noise Clocks
Abstract : A high-speed multi-phase oscillator based on self-timed ring is proposed. Self-timed rings (STR) are promising approach for designing high-speed serial links and clock generators. Indeed, the architecture of STR allows us to achieve high frequencies with multiphase outputs and their oscillation frequency is not only depending on the number of stages but also on the initial state of the ring. Moreover, this architecture allows us 3 dB phase noise reduction when, while keeping the same frequency, when the stage number is doubled. In this chapter, we propose a method to design STR able to generate high-speed multi-phase outputs and we suggest a design flow for designing low-phase noise self-timed ring oscillators. A test chip has been designed and fabricated in STMicroelectonics CMOS65nm technology to verify the theoretical claims and validate the simulation results.
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-00750195
Contributor : Lucie Torella Connect in order to contact the contributor
Submitted on : Tuesday, May 2, 2017 - 11:08:02 AM
Last modification on : Thursday, January 21, 2021 - 4:52:01 PM
Long-term archiving on: : Thursday, August 3, 2017 - 12:41:24 PM
File
978-3-642-28566-0_2_Chapter.pd...
Identifiers
Citation
O. Elissati, S. Rieubon, E. Yahya, Laurent Fesquet. Self-Timed Rings: A Promising Solution for Generating High-Speed High Resolution Low-Phase Noise Clocks. 18th International Conference on Very Large Scale Integration (VLSISOC), Sep 2010, Madrid, Spain. pp.22-42, ⟨10.1007/978-3-642-28566-0_2⟩. ⟨hal-00750195⟩
Share
Metrics
Record views
249
Files downloads
214
