VLSI-SoC: Forward-Looking Trends in IC and Systems Design 18th IFIP WG 10.5/IEEE International Conference on Very Large Scale Integration, VLSI-SoC 2010 Madrid, Spain, September 27-29, 2010
Conference papers
Tri-mode Operation for Noise Reduction and Data Preservation in Low-Leakage Multi-Threshold CMOS Circuits
Abstract : Multi-threshold CMOS (MTCMOS) is the most widely used circuit technique for suppressing subthreshold leakage currents in idle circuits. When a conventional MTCMOS circuit transitions from SLEEP mode to ACTIVE mode, voltages of power and ground distribution networks are disturbed. Mode transition noise phenomenon in MTCMOS circuits is examined in this chapter. An MTCMOS circuit technique with three operating modes (tri-mode) is described for noise suppression during activation events. A threshold voltage tuning methodology is presented to further alleviate the mode transition noise with smaller sleep transistors in MTCMOS circuits. Alternative applications of tri-mode MTCMOS for data preservation and leakage power reduction in idle memory elements are also discussed.
https://hal.inria.fr/hal-01516001 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, April 28, 2017 - 2:29:52 PM Last modification on : Thursday, March 5, 2020 - 5:40:19 PM Long-term archiving on: : Saturday, July 29, 2017 - 1:43:56 PM
Hailong Jiao, Volkan Kursun. Tri-mode Operation for Noise Reduction and Data Preservation in Low-Leakage Multi-Threshold CMOS Circuits. 18th International Conference on Very Large Scale Integration (VLSISOC), Sep 2010, Madrid, Spain. pp.258-290, ⟨10.1007/978-3-642-28566-0_11⟩. ⟨hal-01516001⟩
