Conference papers
Analysis and Generation of Logical Signals for Discrete Events Behavioral Modeling
Abstract : This paper presents a proposal for structuring logical signals for discrete events behavioral modeling. Graphical formalisms will be used to illustrate applicability of the proposed techniques. Input logical signals are generated based on the analysis of physical signals coming from the environment and other input logical signals. Their analysis is introduced in the flow of the input signal analysis, defined as pre-processing when using a modeling formalism. Their analysis is done in the first step of pre-processing, allowing to put these signals at the same level of the physical ones, enabling its use in the rest of the signals’ analysis, and also allowing the generation of events and conditions associated with these signals. Likewise, logical signals are also defined in the flow of post-processing, allowing the definition of output logical signals through analysis and composition of the output signals generated by the model execution. The output logical signals are analyzed in the last step of post-processing in order to allow the use of the signals affected by the events in its analysis. The usage of these signals allows improvements in terms of expressiveness and compactness of the resulted models, both directly due to its use as well as by the increase of the possibilities of analysis provided to the following parts of the development flow.
Complete list of metadatas
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01343478
Contributor : Hal Ifip <>
Submitted on : Friday, July 8, 2016 - 2:58:01 PM
Last modification on : Tuesday, October 15, 2019 - 3:36:02 PM
File
336594_1_En_16_Chapter.pdf
Identifiers
Citation
Rogério Campos-Rebelo, Anikó Costa, Luis Gomes. Analysis and Generation of Logical Signals for Discrete Events Behavioral Modeling. 6th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2015, Costa de Caparica, Portugal. pp.147-156, ⟨10.1007/978-3-319-16766-4_16⟩. ⟨hal-01343478⟩
Share
Metrics
Record views
109
Files downloads
390
