Abstract : The concept of dynamic irrigation low limit (DILL) was proposed and the determination method of DILL was given based on crop-water model. The parameters of the crop-water model were calibrated with winter wheat experimental data of 2008 and 2009. The optimal irrigation scheduling of five typical years under different irrigation water supply were determined, which resulted in 58 groups of data on the average soil moisture content of main root zone (0–60 cm) before an irrigation, the corresponding irrigation time, and water supply. The results showed that, the crop yield under the irrigation times of 3 and 2 increased by 7.42% and 5.62% averaged from 2009 to 2013, and the economic benefit increased by 7.64% and 7.24% than those under the empirical irrigation practices, respectively. The irrigation forecast based on DILL provides an important method to implement and dynamically correct optimal irrigation scheduling under limited water supply.
https://hal.inria.fr/hal-02180009
Contributor : Hal Ifip <>
Submitted on : Friday, July 12, 2019 - 3:11:56 PM Last modification on : Friday, July 12, 2019 - 3:12:28 PM
File
Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed
until : 2021-07-12
Hongzheng Shen, Yangren Wang. Study on the Dynamic Low Limit of Irrigation for Winter Wheat. 10th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2016, Dongying, China. pp.173-188, ⟨10.1007/978-3-030-06155-5_17⟩. ⟨hal-02180009⟩
