Reorientation Method to Suppress Simulator Sickness in Home VR Contents Using HMD
Abstract : While home-use HMD including Oculus Rift has been widely spread in the market today, simulator sickness mainly caused by difference between visual information and body sensation has taken up as a problem. Even though it has been proved that simulator sickness is reduced by reflecting actual physical movement to a VR space, many of approaches ever proposed had various restrictions and mechanisms easy to cause simulator sickness. In the current study, such an approach for moving within a VR space is proposed for home-use HMD that is less likely to cause simulator sickness.
Document type :
Conference papers
Complete list of metadatas
https://hal.inria.fr/hal-02128640
Contributor : Hal Ifip <>
Submitted on : Tuesday, May 14, 2019 - 1:53:59 PM
Last modification on : Tuesday, May 14, 2019 - 2:32:56 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2021-01-01
Please log in to resquest access to the document
Identifiers
Citation
Yuki Ueda, Kazuma Nagata, Soh Masuko, Junichi Hoshino. Reorientation Method to Suppress Simulator Sickness in Home VR Contents Using HMD. 17th International Conference on Entertainment Computing (ICEC), Sep 2018, Poznan, Poland. pp.228-234, ⟨10.1007/978-3-319-99426-0_22⟩. ⟨hal-02128640⟩
Share
Metrics
Record views
82
