Recherche - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Filtrer vos résultats
118 résultats
Influence of particle size on the magnetocaloric properties of Mn1.30Fe0.65P0.5Si0.5 powders.
A. Bartok , Michaela Küpferling , Carmen Curcio , Vittorio Basso , Karim Zehani , et al.
7th International Conference on Magnetic Refrigeration at Room Temperature (Thermag VII). Turin, Italy, September 11-14, 2016., INRIM, Sep 2016, Torino, Italy. ⟨10.18462/iir.thermag.2016.0127⟩
Communication dans un congrès hal-01790660v1
Ferromagnetic L10 phase formation in the Mn–Al–C alloys induced by high-pressure spark plasma sintering
Muriel Tyrman , Simon Quetel-Weben , Alexandre Pasko , Loïc Perrière , Ivan Guillot , et al.
2017 IEEE International Magnetics Conference (INTERMAG 2017), Apr 2017, Dublin, Ireland
Communication dans un congrès hal-01760734v1
Image document
Magnetic Loss Versus Frequency in Non-Oriented Steel Sheets and Its Prediction: Minor Loops, PWM, and the Limits of the Analytical Approach
Hanyu Zhao , Carlo Ragusa , Olivier de La Barrière , Mahmood Khan , Carlo Appino , et al.
IEEE Transactions on Magnetics, 2017, 53 (11), ⟨10.1109/TMAG.2017.2701299⟩
Article dans une revue hal-01726122v1
Image document
Loss decomposition in non-oriented steel sheets: the role of the classical losses
Carlo S Ragusa , Carlo Appino , Mahmood Khan , Olivier de La Barrière , Hanyu Zhao , et al.
AIM 2016, Mar 2016, Bormio, Italy
Communication dans un congrès hal-01726118v1
Image document
Optimization of multiroute synthesis for polyaniline-barium ferrite composites
Tayssir Ben Ghzaiel , Wadia Dhaoui , Alexander Pasko , Frédéric Mazaleyrat
Materials Chemistry and Physics, 2016, ⟨10.1016/j.matchemphys.2016.05.008⟩
Article dans une revue hal-01316638v1
Image document
Loss separation in soft magnetic composites
Olivier de La Barrière , Carlo Appino , Fausto Fiorillo , Ragusa Carlo , Hamid Ben Ahmed , et al.
Journal of Applied Physics, 2011, 109, pp.07A317
Article dans une revue hal-00584717v1
Image document
A method to decrease the harmonic distortion in Mn-Zn ferrite/PZT and Ni-Zn ferrite/PZT layered composite rings exhibiting high magnetoelectric effects
V. Loyau , V. Morin , Jérôme Fortineau , M. Lobue , F. Mazaleyrat
Journal of Applied Physics, 2015, 118, pp.154101 - 154101. ⟨10.1063/1.4933266⟩
Article dans une revue hal-01328469v1
Les matériaux magnétiques durs : état de l’art et tendances
Frédéric Mazaleyrat
Journée Inter GT SEEDS - Machines non conventionnelles - Modèles analytiques - Matériaux magnétiques, Jan 2019, Cachan, France
Communication dans un congrès hal-02061262v1
Image document
Anisotropy of the ferromagnetic L1 0 phase in the Mn-Al-C alloys induced by high-pressure spark plasma sintering
Muriel Tyrman , Smail Ahmim , Alexandre Pasko , Victor H. Etgens , Frederic Mazaleyrat , et al.
AIP Advances, 2018, 8 (5), pp.056217. ⟨10.1063/1.5007241⟩
Article dans une revue hal-01681390v1
Image document
Heat management and losses of electrocaloric cooling devices based on electrostatic thermal switches
Lucas Depreux , Morgan Almanza , Nouh Zeggai , Fabien Parrain , Martino Lobue
Applied Thermal Engineering, 2022, pp.118290. ⟨10.1016/j.applthermaleng.2022.118290⟩
Article dans une revue hal-03616477v1
Image document
Numerical study of thermomagnetic cycle
Morgan Almanza , Alexandre Pasko , Frédéric Mazaleyrat , Martino Lobue
Journal of Magnetism and Magnetic Materials, 2016, ⟨10.1016/j.jmmm.2016.11.058⟩
Article dans une revue hal-01400798v1
Image document
Hard magnetic properties of melt-spun Mn-Al-C alloys
Alexandre Pasko , Frederic Mazaleyrat , Martino Lobue , E. Fazakas , L. K. Varga
EPJ Web of Conferences, 2013, 40, pp.06008. ⟨10.1051/epjconf/20134006008⟩
Article dans une revue hal-00827620v1
Image document
Structural and magnetic properties of an anisotropic M-type LaCo-substituted strontium hexaferrite
Muriel Tyrman , Alexandre Pasko , Olivier de La Barrière , Frédéric Mazaleyrat
European Physical Journal: Applied Physics, 2015, ⟨10.1051/epjap/2015150099⟩
Article dans une revue hal-01259667v1
Image document
Rotational magnetic losses in non-oriented Fe-Si and Fe-Co laminations up to the kHz range
C Appino , Olivier de La Barrière , C Beatrice , F Fiorillo , C Ragusa
IEEE Transactions on Magnetics, 2014, 50 (11), ⟨10.1109/TMAG.2014.2325968⟩
Article dans une revue hal-01327664v1
Optimization of magnetic flux paths in transverse flux machines through the use of iron wire wound materials
Artur Giedymin , Théodore Cherrière , Fatih Avcilar , Uwe Schafer , Frederic Mazaleyrat
2019 IEEE 12th International Symposium on Diagnostics for Electrical Machines, Power Electronics and Drives (SDEMPED), Aug 2019, Toulouse, France. pp.23-29, ⟨10.1109/DEMPED.2019.8864913⟩
Communication dans un congrès hal-03777566v1
Image document
Convertisseur DC-DC à transistors GaN entrelacé couplé par TICs monolithiques frittés par SPS
Adrien Mercier , Fabien Adam , Denis Labrousse , Bertrand Revol , Oleksandr Pasko , et al.
Symposium de Genie Electrique, Jun 2016, Grenoble, France
Communication dans un congrès hal-01361617v1
Image document
Cobalt Doping Effect on Ni-Zn-Cu Ferrites Produced by Reactive Sintering
Adrien Mercier , Gérard Chaplier , Alexandre Pasko , Vincent Loyau , Frédéric Mazaleyrat
Physics Procedia, 2015, 75, pp.1306 - 1313. ⟨10.1016/j.phpro.2015.12.146⟩
Article dans une revue hal-01448858v1
Image document
First vs second order magnetocaloric material for thermomagnetic energy conversion
Morgan Almanza , Alexander Pasko , Frédéric Mazaleyrat , Martino Lobue
IEEE Transactions on Magnetics, 2017, ⟨10.1109/TMAG.2017.2697398⟩
Article dans une revue hal-01514750v1
Image document
Étude d'aimants hexaferrites anisotropes de nouvelle génération
Muriel Tyrman , Oleksandr Pasko , Olivier de La Barrière , Frederic Mazaleyrat
Symposium de Génie Électrique 2014, Jul 2014, Cachan, France
Communication dans un congrès hal-01065167v1
Image document
XXIst Century Ferrites
Frederic Mazaleyrat , Alexander Pasko , Martino Lobue , Karim Zehani
INTERNATIONAL CONFERENCE ON RECENT TRENDS IN PHYSICS (ICRTP 2012), Feb 2012, Indore, India. pp.012001, ⟨10.1088/1742-6596/365/1/012001⟩
Communication dans un congrès hal-00823868v1
Image document
A computationally effective dynamic hysteresis model taking into account skin effect in magnetic laminations
Olivier de La Barrière , Carlo Ragusa , Carlo Appino , Fausto Fiorillo , Martino Lobue , et al.
Physica B+C, 2014, 435, pp.80 - 83. ⟨10.1016/j.physb.2013.09.036⟩
Article dans une revue hal-01100311v1
Image document
Étude et mise en oeuvre de résonateurs magnétostrictifs, application à la mesure de givrage
Yannick Le Bras Le Bras
Autre [cond-mat.other]. Université du Maine, 2011. Français. ⟨NNT : 2011LEMA1014⟩
Thèse tel-00675539v1
Image document
A thermal energy harvester using LaFeSi magnetocaloric materials
Smail Ahmim , Morgan Almanza , Vincent Loyau , Alexandre Pasko , Frédéric Mazaleyrat , et al.
IEEE Transactions on Magnetics, 2021, ⟨10.1109/TMAG.2020.3008753⟩
Article dans une revue hal-02925562v1
Image document
Classical eddy current losses in Soft Magnetic Composites
Carlo Appino , Olivier de La Barrière , F . Fiorillo , Martino Lobue , Frédéric Mazaleyrat , et al.
Journal of Applied Physics, 2013, 113 (17), pp 17A322-1 - 17A322-3
Article dans une revue hal-00825523v1
Image document
Study of magnetic losses in Mn-Zn ferrites under biased and asymmetric excitation waveforms
Martino Lobue , Vincent Loyau , Frédéric Mazaleyrat
IEEE Transactions on Magnetics, 2010, 46 (2), pp.451-454. ⟨10.1109/TMAG.2009.2031471⟩
Article dans une revue hal-00658859v1
Image document
High-frequency rotational losses in different Soft Magnetic Composites (SMC)
Olivier de La Barrière , C Appino , C Ragusa , F Fiorillo , F Mazaleyrat , et al.
Journal of Applied Physics, 2014, pp.17A331-1-17A331-3
Article dans une revue hal-01100338v1
Image document
Enhancement of the magnetoelectric effect in multiferroic CoFe2O4/PZT bilayer by induced uniaxial magnetic anisotropy
Alex Aubert , Vincent Loyau , Frédéric Mazaleyrat , Martino Lobue
IEEE Transactions on Magnetics, 2017, 53 (11), pp.1-5. ⟨10.1109/TMAG.2017.2696162⟩
Article dans une revue hal-01636268v1
Image document
SPS co-sintered monolithic transformers for power electronics
Adrien Mercier , K. Zehani , G. Chaplier , A. Pasko , V. Loyau , et al.
IEEE Transactions on Magnetics, 2016, 52 (5), pp. 8400404. ⟨10.1109/TMAG.2015.2504876⟩
Article dans une revue hal-01340090v1
Image document
An analysis of Mn-Zn ferrite microstructure by impedance spectroscopy, scanning transmission electron microscopy and energy dispersion spectrometry characterizations
Vincent Loyau , G.Y. Wang , Martino Lobue , Frédéric Mazaleyrat
Journal of Applied Physics, 2012, 111 (5), pp.053928
Article dans une revue hal-00738002v1
Ferrofluides - Nanoparticules superparamagnétiques
Irena Milosevic , Laurence Motte , Frederic Mazaleyrat
Techniques de l'Ingénieur, Editions T.I., pp.N 4 590 1-14, 2011, Matériaux Fonctionnels
Chapitre d'ouvrage hal-00608871v1
