Conference papers
Vector Sensor Arrays in Underwater Acoustic Applications
Abstract : Traditionally, ocean acoustic signals have been acquired using hydrophones, which measure the pressure field and are typically omnidirectional. A vector sensor measures both the acoustic pressure and the three components of particle velocity. Assembled into an array, a vector sensor array (VSA) improves spatial filtering capabilities when compared with arrays of same length and same number of hydrophones. The objective of this work is to show the advantage of the use of vector sensors in underwater acoustic applications such as direction of arrival (DOA) estimation and geoacoustic inversion. Beyond the improvements in DOA estimation, it will be shown the advantages of using the VSA in bottom parameters estimation. Additionally, is tested the possibility of using high frequency signals (say 8-14 kHz band), acquired during the MakaiEx 2005, to allow a small aperture array, reducing the cost of actual sub-bottom profilers and providing a compact and easy-to-deploy system.
Document type :
Conference papers
Complete list of metadatas
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-01060754
Contributor : Hal Ifip <>
Submitted on : Thursday, November 16, 2017 - 10:56:49 AM
Last modification on : Wednesday, November 29, 2017 - 11:24:07 AM
Long-term archiving on: : Saturday, February 17, 2018 - 4:21:56 PM
File
SantosFJ10.pdf
Identifiers
Citation
Paulo Santos, Paulo Felisberto, Sérgio M. Jesus. Vector Sensor Arrays in Underwater Acoustic Applications. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.315-322, ⟨10.1007/978-3-642-11628-5_34⟩. ⟨hal-01060754⟩
Share
Metrics
Record views
158
Files downloads
581
