Conference papers
Test Based on Built-In Current Sensors for Mixed-Signal Circuits
Abstract : This paper presents a test methodology for mixed-signal circuits. The test approach uses a built-in sensor to analyze the dynamic current supply of the circuit under test. This current sensor emphasizes the highest harmonics of the dynamic current of the circuit under test when the current to voltage conversion is done. The goodness of the test method is analyzed first by means of a fault simulation and afterwards through the experimental data obtained from several benchmark circuits.
Document type :
Conference papers
Complete list of metadatas
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01060778
Contributor : Hal Ifip <>
Submitted on : Thursday, November 23, 2017 - 4:29:02 PM
Last modification on : Wednesday, November 29, 2017 - 12:07:52 PM
File
MozuelosLMB10.pdf
Identifiers
Citation
Román Mozuelos, Yolanda Lechuga, Mar Martínez, Salvador Bracho. Test Based on Built-In Current Sensors for Mixed-Signal Circuits. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.521-528, ⟨10.1007/978-3-642-11628-5_58⟩. ⟨hal-01060778⟩
Share
Metrics
Record views
159
Files downloads
208
