Emerging Trends in Technological Innovation First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems, DoCEIS 2010, Costa de Caparica, Portugal, February 22-24, 2010
Conference papers
A CMOS Inverter-Based Self-biased Fully
Differential Amplifier
Abstract : A CMOS self-biased fully differential amplifier is
presented. Due to the self-biasing structure of the amplifier and its
associated negative feedback, the amplifier is compensated to achieve
low sensitivity to process, supply voltage and temperature (PVT)
variations. The output common-mode voltage of the amplifier is adjusted
through the same biasing voltages provided by the common-mode feedback
(CMFB) circuit. The amplifier core is based on a simple structure that
uses two CMOS inverters to amplify the input differential signal.
Despite its simple structure, the proposed amplifier is attractive to a
wide range of applications, specially those requiring low power and
small silicon area. As two examples, a sample-and-hold circuit and a
second order multi-bit sigma-delta modulator either employing the
proposed amplifier are presented. Besides these application examples, a
set of amplifier performance parameters is given.
https://hal.inria.fr/hal-01060780
Contributor : Hal Ifip <>
Submitted on : Friday, November 17, 2017 - 4:41:23 PM Last modification on : Wednesday, November 29, 2017 - 12:09:43 PM Long-term archiving on: : Sunday, February 18, 2018 - 4:30:36 PM
José Rui Custódio, Michael Figueiredo, Edinei Santin, João Goes. A CMOS Inverter-Based Self-biased Fully
Differential Amplifier. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.539-546, ⟨10.1007/978-3-642-11628-5_60⟩. ⟨hal-01060780⟩
